Old 06-10-2018, 03:43 AM   #10 (permalink)
Crashy
All the losses in the alt are from hysteresis and drag from the fan
There are MANY other losses:
Bearing friction
Rotor current
Diode losses
Regulator losses
Stator losses (resistive)
Rotor losses (resistive)
Magnetic losses
If the fan is such a big loss, don't spin it. Alternator delete vs disconnect. Obviously NOT a huge loss from the fan or everyone would be deleting instead of just disconnecting. The fan would not be required if the resistive and conversion losses were not so bad.
