Thread: Wheel bearings
Old 06-10-2018, 11:22 AM   #15 (permalink)
roosterk0031
Bet it would screw up the abs wheel speed sensor/ring gear. For most of my cars 150-160,000 is when they start going bad (except my 1994 explorer much sooner but wasn't sealed bearing) Tried Ebay bearing on my Cobalt, 12,000 later replacing it with MOOG, other one was bad in a few more month.
On Cam's rogue one was bad, we just went ahead and replace both 2nd one is so much easier if you do it same day.
One mower I had, the spindles were aluminum, I never done it before but used a drill to drill the holes then run a tap in, 10 minutes grease zerts installed, sounded better afterwards. Current mower they are sealed. 54" Hustler for <1/4 acre of grass doesn't see much use since we've quit mowing for other people.
