Old 06-12-2018, 12:19 AM   #726 (permalink)
freebeard
My personal thoughts turn to modelability. How accurately can you define the surface? The solution seems to be a octahedral-based geodesic structure.
If you like I can show* the progression from a sphere, to a 30/70 front-rear split, cross-section that is prolated above the equator and oblated below and flat-bottomed, with an overall resemblance to a humped-backed Dymaxion.
This relies on a linear transformation fore and aft of 'center'. With added complexity you could have a non-linear transform produce a reflex curve and stinger tail. The handful of data points that defineWhy does The Template have to be a half body of revolution? the [un-mirrored] half shape can still be calculated to as many decimal point as you require.
Further transformation. I haven't found a way to apply this to the octahedral geodesic, but it could probably be done station-by-station. A squircle can be anywhere between a square and a circle.
This can resolve packaging issues, like windshield headers without upper corners, and etc. The subject is covered here:
edit:
*Permalink #29
Walk without rhythm and it won't attract the worm. --fatboy slim
_________________
aerohead (06-13-2018)
