Old 08-30-2008, 10:19 AM   #520 (permalink)
bennelson
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
Looks like it wasn't the sliders.
I pulled the caliper off the disc. Then took the pads out. With the parts apart, the sliders themselves seemed to work fine.
When I pushed on the brake pedal, the pressure would wiggle the whole caliper unit hanging on the wire from the suspension, but the piston itself didn't move at all.
I pushed a little harder and pumped the brakes. All the sudden, the brake pedal went down much further, and the piston moved quite a bit.
It came almost all the way out. I pulled it the rest of the way and could see there was surface rust on it. Probably why it wasn't moving. Can I grind off that surface rust real careful and re-use the piston, or do I buy a new one?
It also looks like the piston dust boot is torn and there is some corrosion inside the caliper bore as well.
I think I am going off to the auto parts store to see what they have there, how much it costs, etc.
Any suggestions people? Please let me know! Thanks.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
