Old 08-30-2008, 04:43 PM   #4 (permalink)
minic6
minic6
minic6's Avatar
Kammback
This is in the proof mode. jwxr7 swears by his, so we will see, getting close to a fill up. Tank was filled right after this was done. Luan paneling was used, corners were fiberglassed and then all the wood was coated with the mixed glass. If it helps it will be blended in. 2nd donor car has a good hatch to go back stock or lengthen the kammback.
