Hey everyone.
Wanting to lose some weight on my euro 1991 mk2 crx vtec !
I know to start off with the b16a vtec engine is quite thirsty - however this is the car i have and im not changing the car or the engine .
Losing weight will not only increase mpg ( slightly lol ) but also make my car a little bit quicker ( overtaking etc ) so a bonus on both fronts !
Just so you guys know ive got the heaviest crx made weighing ( from a couple of sources ) at least 2220lbs up to 2400lbs !... compared to the " lower spec " models is a huge amount of weight difference! And this one doesnt have the heavy door mounted seatbelts. It doesnt have aircon or ps either !
Was looking for opinions on how to reduce weight on my honda crx, without lossing the back seats and carpets. I want the car to look stock in and out ,basically.
I have a couple of ideas so far ( and have done a few already ) :
1: Replace sunroof ( and headlining and motor + wires ) with fiberglass bung. Told this should save me around 15kg alone !
2: Lightweight Battery
3: Lightweight wheels (done : just bought some very lightweight 15" alloys )
4: Rear wiper + motor + wiring delete
5: spare wheel, jack and tools
6: rear standard wing delete - think this is going bye bye too.
7: mudflaps delete ( done )
8: im thinking lexan windows in the rear - anyway to do this and maintain the " stock " look ? They always seem to be riveted on , rather than bonded on ?
9: Remove the ABS ecu , sensors, wiring , and servo.
10 : soundproofing removed?
11 : side impact door beams delete ? possible?
Any more ideas or views on the above , will be appreciated !
One race team got one of these down to around 700kg , however this was completely stripped and probably used titanium fasteners etc !
Regards
Mark
