heres a couple in the building stage. I will post a couple of it done maybe later today if the weather cooperates.
The battery's are from walmart. 75 amp hour marine grade. I used go kart rear disk brakes . The rear shaft is 3/4 in cold rolled keyed the whole length..
here is one of my front wheel drive setups. it is 60 volts, range 75 + miles and top speed of 38 mph. This is what i use on the green way. I have one more exactly like it for my wife also
