Old 09-02-2008, 02:18 PM   #3 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
If the home-made alcohol is similar to Ethanol, you could essentially mix it with 15% gasoline to make E85.
BUT...
Flashback to the 20's/30's -- homemade alcohol is banned despite the lift of prohibition. Meanwhile, backwoods "stills" operated, until the "revenuers" (IRS-Agents) found them, charged the owners, taxed the consumption, and destroyed/confiscated the apparatus.
In this day and age, the same would likely apply + the expectation in many States to pay road taxes per gallon (similar to the homebrew Bio-Diesel problem).
Denaturing the alcohol (by mixing it with gas) might get you out of the "personal consumption / intent to sell" charges and taxes, but the road taxes might still come back to get you. Uncle Sam wants his $$$.
(In other words, check local laws)
How much corn would that require, by the way?
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
