Old 09-02-2008, 05:02 PM   #97 (permalink)
aerohead
Your illustration looks real good! With the upswept radiused leading edge,the flow should transition right onto the new panel just like the flow illustrator depicts.I'd go for it.If the driveshaft requires a lot of vertical articulation that might strike the panel,you could break it into two separate pans without losing much to drag.Your work looks great,look forward to your next installment!
