Well, that flywheel issue needn't be an issue to other users. The one we had just had six bolts in a circle. If someone put a flange on their motor shaft, they'd be set.
Sounds like you're on the right track. I just know you're well researched in all ways ev-conversion oriented, and was wondering if other people were using other products.
I still think you should use my brake-activated brake-assist brainstorm nugget. It'd be the hottest thing under the sun.
