Old 09-02-2008, 07:29 PM   #21 (permalink)
Gabier
Originally Posted by Tango Charlie View Post
No, I don't think you can see them in the photo. You can see them in the video. If you pause at 1:35 they're right there. It doesn't look like they're moving with the breeze much.
Those are called "reef points", they are used to reduce the sail area in heavy winds. A simple way of explaining how it works: you roll the bottom of the sail and tie it to itself using the reef points, then raise the sail, wich is now not as high and not as big.
