Old 09-03-2008, 02:01 PM   #32 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Officelinebacker,
I'm afraid you've misunderstood, so I'm going to parse your post out so it is easier to understand my responses:
Originally Posted by OfficeLinebacker View Post
I get the reasoning behind choosing understeer vs. oversteer, but my personal preference is oversteer.
This isn't understeer or oversteer. This is no steer - in other words, loss of control.
For me understeer means I just keep going straight into whatever I was trying to avoid. Sure there's a slight chance that traction will return, but for me that only happens when I realize that having max. press. on the brake isn't working, I let up, and the car suddenly turns at the last second.
When I spin out, true I have less control, but at least I am not pointing exactly in the direction I am trying to avoid.
You may not be pointed in that direction, but you're headed in that direction (but pointed sideways or backwards!) with no opportunity to correct the direction of travel.
I realize, this is somewhat counter-intuitive, but I've had more luck when I went off track nose first, than when I went rear end first. When going off front end first, there was a speed were the grip came back and I could steer again, but when I went off tail end first, I had to wait for the racecar to come to a complete stop before I could manuever again.
This isn't about personal preference or comfort. This is about safety and it should come first.
