01-09-2007, 08:14 Pm
If I understand Jerry's setup, his pot box latching relay prevents the pack +ve contactor from closing if the ignition is switched on while the go pedal is pressed.
His approach is sort of equivalent to forcing you to depress the clutch before starting a manual, or pressing the brake to shift out of park.
I omitted that precaution.
