Old 09-04-2008, 01:23 AM   #586 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Originally Posted by ac7ss View Post
The cDA/cRR would be interesting, but how often would you use it? I could see making a separate program that would run in the same hardware setup (write down the hard earned variables for your car first.)
You are probably correct, I, or someone, should just hack the current program into a standalone cda calculator you can load when you need it. The current setup includes weight and vss pulses, inj, etc, and it will still be in the eeprom when you load the cda program.
