Old 09-04-2008, 06:43 PM   #12 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 43.98 mpg (US)
Hello -
Last Monday I finally finished the passenger side skirt. It took longer because I had to carefully match up (eyeball) the attachment holes to match the driver side skirt. I am happy with the results :
Passenger and Driver Side :
Driver Side Close-up :
To solve the size/gap problem, I just added black spongy insulation tape :
Driver Side detail of spongy insulation tape :
Here is the splash-guard front air deflector. I will replace this with a better picture later :
Driver Side Front View with splash gaurd and Rear View :
Problem: I have noticed that the plastic is flappy on the bottom where I cut it in half. While I haven't seen it hit, I see little dents in my center lug-nut plate. I don't mind this, but I think this could cause "negative aero" if it starts vibrating at speed X. I should do a film to find out if it is flapping but I am too lazy right now. I know I can solve this with rigid metal strip.
CarloSW2
American Solar Energy Society
