Old 09-04-2008, 06:52 PM   #13 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
Hello -
Here is another issue I had with the installation. I'll start with this picture of idealized top-view cutaways :
Wheel Well Fitment :
Here are their explanations :
1 - If the wheel well and water heater pan are an exact match, you get a perfect fit. This is the ideal.
2 - If the wheel well is a little bit too small, then you can get a situation where the drain pan "bows out". I think this is next to ideal and in fact the shape we usually incorporate in wheel skirts anyway.
3 - If the wheel well is a little bit too big, then attaching the sides of the drain pan can cause it to "bow in" and hit the wheel. This is in fact what happened to me.
3A - My solution was to add rubber spacers between the pan and the wheel well in order to make it closer to image #1. The spacers were only needed at the lower connections. There is still some bow, as you can see in this picture if you look closely :
Driver Side Rear View :
CarloSW2
American Solar Energy Society
