Old 09-05-2008, 03:24 AM   #562 (permalink)
EVDRVR
Originally Posted by bennelson View Post
Right after that, I put it into second. I think 30 mpg is the fastest it has gone so far in second.
Ben,
Just how fast is 30 mpg in 2nd?
Have been reading the saga a little at a time. I sort of picked up at the end. I'll give you some charging info on the gels along with some battery opinion and a comment about vacuum pumps. (I missed any particulars as to your charger and history so forgive me if I wasting words here. Sure not trying to insult anyone or be redundant.)
Deka says charge to 2.30V to 2.35V volts per cell for the gel batteries and a float of 2.25V to 2.30V. The charger in my Force was profiled for the upper end 14.1 volts per battery during charge and the lower 13.5V during float. Charging voltage needs to be temperature compensated to avoid over and undercharging.
As you know if you have a 10 gal gas tank and you use ten gallons you only need to put back ten gallons to fill it up. Batteries don't work that efficiently and it gets really complicated as to how much, how fast, and how you put the charge back into the pack. It is a subject of great complexity and has many right answers. It is the wrong ones you want to avoid.
It gets even more complicated when you put a Pba battery in a EV. A EV is pretty much living hell on a battery. You'll almost always be operating at around the 1hr rate or less. Unless you have some monster batteries that 100ah rating you mentioned is likely at 20hr rate or at least 5.
Solectria runs a overcharge of 10% to get a full charge using the charger that is in my car on the 13 battery string. They have run as high as 15%- 20% in some other profiles. This is a balancing charge.
As your string is shorter you might want to use slightly less. Voltage balance becomes a serious issue as the string gets longer and or the amp load on the batteries gets higher. High amps and long strings increase the "evil" outcome. Solectria overcharged the grp 27 gels in the Force @ 3 amps to a max voltage of 15 volts per battery. You do not want to go to 15 volts unless you have a sophisticated charger. Observe the 14.1V limit.
Most people I know would advise against using a Deka Gel battery in a EV unless it was going to be limited to a fairly low amp load almost all of the time. Deka gels will last a long long time in the right conditions, low amp loads being one of them. The Force operates almost all of the time below 200 amps and predominately below 100. At 30 mph it is using about 30 amps. Higher voltage means less amps and the AC induction motor by design requires less than a DC motor.
Ecomodder's drive smart to save gas, EV owners drive smart to keep the load off the battery. Pba batteries are like little children, how they are treated every day determines the outcome.
You can go out a "hot rod" a tank of gas without any effect on the new fuel. What you do to a battery pack is there until replaced. So when you hear individual results about battery performance being good or bad a lot can be attributed to the throttle actuator.
Gel batteries need a rather special break-in or unrepairable damage can be done. Two gentle cycle's when new best done with a load other than the motor. Then really baby them for awhile. The return is a much longer life and better capacity. Solectria recommends a low amp discharge to a about a 30 ah discharge followed by an immediate recharge. We use the heater in the Force. It draws a 10 amp load and this takes about 3 hours. Ideally do this twice before operation under power in the car. Then the you should drive gentle (less than 150 amp load and consume no more than 20 AHs on a grp 27) everyday for another 10 charges to maximize longevity and performance.
Vacuum pumps.
You can buy a number of pumps made just for use in a EV. This might be a place in which to spend some money if your not going to be the only driver. When we really know a vehicle well we can forget other don't, and they might have false expectations.
With a electric pump you really may not need a vacuum cannister. Sort of depends upon pump size verses brake booster. My vehicle simply has about 2 feet of hose wrapped around the pump. Remember your never going to be in a zero vacuum WOT condition with the EV. When the pressure drops the pump comes on, pressure up pump off.
Unless the a/c is on, the vacuum pump cycling once when I turn the key is the only sound to be heard.
My pump cycles on after about two pumps of the brake pedal. Off again in just a few seconds.
A friend is turning a 90's Avanti into a EV and using a Harley tranny, a Corvette rear end and a 9" mid engine mounted motor. This is after a body off restoration to kill the rust. He bought a Metro to convert but decided the Avanti was what he really wanted to do. There is always deeper water.
Keep up the good work, it sounds like your having a good time.
Stay charged up and if you haven't met our Pba EV friend/nemeses "Peukert" give him a Google.
EVDRVR
