Originally Posted by Will
One problem is my alignment. I have had it fixed, but due to the damage my driver’s side tire is two inches behind my passenger side. This seems to be ok, but the car vibrates at higher speed.
I am not your mother, but may I suggest that you go to your closest body shop with a fairly expensive piece of equipment called a Frame Straightener. Have them straighten the frame, grind off the spots that they make when they clamp the frame, and have them perform a four-wheel alignment. This will solve your vibration issues. The frame being this, for the lack of better words, ----ed up, you will whip though tires, lack control at high speed, and present a dangerous hydroplaning potential in the rain. Just my $0.02. Good luck and keep on Hypermiling
