Old 09-05-2008, 02:52 PM   #6 (permalink)
mavinwy
Neon1 - '97 Neon highline
90 day: 27.26 mpg (US)
Yep...An object in motion tends to stay in motion until outside energy changes the velocity.
That could be friction, a curve, gravity, wind etc....
Once you get 50k+ lbs moving, it wants to keep going in the line set forth. so once it is at speed, it does not take that much energy to do relatively small changes. A higher gear can be used then to improve efficiency.
Jim
