Old 09-05-2008, 11:19 PM   #19 (permalink)
Clev
Wannabe greenie
The Clunker - '90 Accord EX sedan
90 day: 29.49 mpg (US)
Uranus - '04 Ion 2 sedan
90 day: 38.21 mpg (US)
Mountain Goat - '96 Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Originally Posted by Gregte View Post
Well then why don't we ecomodders raise, or lower, our final drive gear ratios by changing differential gears?
Trucks have more gears because diesels have a much more limited RPM range. And once you are up to hiway speed the only gearing that matters is your final drive gear. More gears has nothing to do with hiway driving for a car unless your terrain is so hilly that you would actually be downshifting on the hiway.
If I had RWD, I would, but I don't know enough about FWD transmissions to comfortably replace the gear.
