Old 09-06-2008, 10:04 AM   #596 (permalink)
ptsmith24
ptsmith24's Avatar
El Camrino - '90 Camry LE
90 day: 32.47 mpg (US)
Originally Posted by ac7ss View Post
Quite possibly the fact that you do not have anything hooked up is causing the inputs to float. Try grounding the inputs, that should fix the false indication. (I did not see any demo mode in the code.) If the problem continues, double check the connections you have made.
After posting, I finished connecting the diodes to ground. The last post, I had connected everything that didn't deal directly with vss/inj inputs. So, everything is ready to be connected to power, ground, vss, and inj 0v. I'm about to go out and find those leads now. I'll be sure to post back some specifics for any 2nd generation camry owners that may be on here.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
