I finally got it all working. The pulses/mile seems to be accurate (distance is within 0.01 mile over 3 miles) But, the speed jumps a good bit (for example, going 20, it jumps 15-25 and everywhere in between). The usec/gallon must be way off (by a factor of 3 or 4, maybe?) The mileage at 45MPH is showing 7MPG (should be 3-4 times that). From my wiring diagram for my ECU, it looks like 2 of the injectors fire at the same time, alternating with the other 2. Could that be affecting that number? I put in an initial usec/gallon of 296052631 (assuming 6.25 lbs/gallon, 19 lb/hour injectors). I'll go ahead and put in a wiki entry with these numbers and put a note that I'm still calibrating.
edit: another note: be careful with the wiring in older cars. I broke my VSS lead in two and had to reconnect that before splicing in again.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
Reason: added
