Old 09-07-2008, 04:27 PM   #18 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Originally Posted by ac7ss View Post
Likely, the downslope and upslope are causing the difficulty.
Well, if you like, around position 1159760 in that file, the speed should be pretty steady, but I think you will find that the large verticals are not evenly spaced, likely due to mechanical "slop". The data is all there and you were the one who said it was "easy" You might have to look at more than one pulse though.
of course, if we had a trace output of the anomalous pulses it would be easy to determine the easy way to screen them out.
