Old 09-09-2008, 02:26 PM   #1 (permalink)
wagonman76
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Restricted fuel system affect mpguino readings?
Ive charted my last few mpguino tank readings compared to actual fuel usage. It started out very close, then read 4% high on fuel use twice, then last time was 8.5% high on fuel use.
Ive also had a couple times in the last few tanks where the fuel seems restricted, and it acts like it is almost out of gas for a bit. I know, I need to change the fuel filter since the pump seems to act just fine.
But anyway, I was wondering if this could actually cause the readings to be skewed? Like say the injectors are firing (and even firing even longer because of more throttle while attempting to go faster) but the actual fuel is not getting through. So fuel usage reads high. Until the computer compensates, if it even can accurately.
And if this is the case, this could even be a bonus of the mpguino, if the fuel usage starts to read high fuel usage (or low mpg), it could be a sign of reduced fuel pressure and an early warning to fuel system problems.
Winter daily driver, parked most days right now
Summer daily driver
