Old 09-10-2008, 04:32 PM   #11 (permalink)
Bullockracing
Icarus - '011 Mustang GT
90 day: 20.71 mpg (US)
NGK non-suppression plugs, and premium wires. You are not looking to remove resistance, but resistivity, which is resistance in relation to diameter. Iridium and platinum are good for longevity, as previously stated. Splitfires suck (in every vehicle I've ever tried them in at least - 6 of them). I've had good luck with AC Rapidfires - on high performance ignitions at least. I currently run NGK non-suppression Iridiums - my car doesn't take wires. I would recommend Taylor 10.4mm wires if they have a set for you, if not, get minimum 9mm wires - highest quality you can afford...
