Old 09-11-2008, 01:20 PM   #3 (permalink)
Frank
Originally Posted by oldtech1 View Post
now i havent looked into the real possibilitys vs amp created to amper use on conversion but ....
what if you took a small motor like a weedeater or chain saw and used it to turn a alternator or combo aternator to achieve 24 volts or other type of motor to make energy then send it thru controller to final motor drive.
im not saying this is a viable idea but just a thought to ponder on.
send feedback
and yes i know a 2 stroke motor would not be a good alternative and more pollution but a 4 stroke of equivelent size with some tourqe.
or to make full electric bike but use 20cc motor powering alternator to make a
plug in hybrid type cycle
Sadly, I don't think there's much point doing it this way. Typically the energy conversions cost you: generally you're better off driving the wheels directly.
Something I've thought of is using a small displacement single-cylinder ICE and somehow incorporating a permanent magnet motor to it, with batteries. I think it could be connected for battery assist (ex. acceleration) then it could cruise relatively efficiently at whatever speed you could get out of it. The motor could regen to provide braking force and recharge the batteries a bit. The engine could drive the motor in battery charging mode if battery SOC got too low. I suspect a relatively small battery pack might be used for quick acceleration.
