Old 09-11-2008, 02:43 PM   #48 (permalink)
trebuchet03
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
Originally Posted by dremd View Post
Got a source on that?
My Calculations indicate that 140KW = 187 hp
Doh! That should have been 140MW - which is an estimation...
Maths
747-400 Powered by 4 Rolls-Royce RB211-524H2-T with a Thrust of 264KN multiplied by 4 engines is 1056KN of thrust (264KN comes from 747-400 website, see link below). Here's an interesting tidbit according to Rolls-Royce "Every 34 seconds an RB211-524 powered 747 takes off or lands" (jet engines for the Boeing 747-400 - Rolls-Royce).
Power = F*v
Typical Cruising speed of a 747 (Boeing: Commercial Airplanes -- 747 -- 747-400 Technical Characteristics) : Mach .85 = ~290m/s @35K feet
So, worst case scenario, a 747 requiring 100% thrust @ cruising speed...
920*290=~306MW
That's not realistic - turbines are throttled back while Cruising - to what % is debatable, so here's a spread...
% | Power (As function of %thrust)
90 = 275MW
80 = 244MW
70 = 214MW
60 = 183MW
50 = 153MW
40 = 122MW
30 = 91MW
20 = 61MW
10 = 31MW
Oh, don't forget the 1450hp APU (you do want a pressurized cabin and hydraulic controls, right?) - which is roughly 1MW...
140MW puts us right around 45% throttle, which doesn't seem unreasonable and is also found on this page ( Orders of magnitude (power - Wikipedia, the free encyclopedia) ). Remember, I used the least powerful engine option for these quick calcs
Many of these values have been rounded, several times - this is a back of an envelop calculation as I don't feel like spending much time on this. I'm also aware of the assumptions necessary to make these estimations - you don't need to be an ass and tell me what I already know unless you know the range of drag forces of a 747 while cruising.
alot of informative conversation here...
ever looked at u-joint of a rig, then a 3/4 ton pickup? they are playing with mere inches of difference for up to 150 THOUSAND pounds difference (log trucks can haul with a 550hp engine 150,000 pounds). The claims they cannot do better for vehicles and power to weight is hogwash. And furthermore, a 550 hp with 3.7 rears and a 15 speed is faster than my 13 second sube. A driver knows what to skip for gears and when, when empty. The only thing losing mileage is engineers, I hope they run out sooner than later..pun intended.
To add more to a cure: a 3 main boxer is as close as man has ever gotten to maximizing thoughts of power to weight for car sized vehicles and ICE.. No need to prove it with crazy you-tube vids of unbelievable subaru beatings of the 3 main classic, a bit of reading reaveals a type 1 vw still has the world record of 202 mph above ALL four cylinders. The more I learn the crazier I get...
A karl benz crank in a 4 liter 90 degree v8 would drop the jaws of entire gooked nations...
RIDICULOUS TO FALL INTO THE HELMS OF BABBLE.
Dear God Have Mercy...
Pie?
I really couldn't follow much of that, I felt like I was reading the text in spam eMail o.0
Challenge me, or correct me, but don't ask me to die quietly.
