Old 09-11-2008, 07:59 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
There are applications (carburetors) that may want to utilize to such an approach, but there are issues that make the injector/vss a good choice.
1. Accuracy. The injector monitoring is proving to be very accurate (knock on wood). Because the car computer takes in many sensors it cannot be as accurate to just monitor airflow. It has to consider pressure/air temp/coolant temp/etc.
2. Universalness. All electronic fuel injected cars can have their injectors monitored with a mpguino. Not all fuel injected cars have the same types of sensors and not all sensors have the same calibration, so you wind up with a lot of complicated instructions just to get the hardware hooked up. It is complicated enough just getting two signals out of the car(injector and vss).
3. Completeness. It is fully functional. Not going to change oars now. Though airflow is still a serious consideration for the carburetor engines, fuel flow would be even better.
4. Cost. Tapping into an injector signal cost nothing, takes no space, and requires only electrical skillz (or good instructions from someone who has already been there). Adding a flow meter will make for plumbing skills and additional costs.
So I'm still keeping my options open for carbs, but fuel injectors are pretty much a done deal.
