Water heater jackets are designed to be compact and tidy. If you don't mind the work of re-doing your work for periodic tank replacement and other maintenance, add as much as you want. Arranging for an easy to restore seam in a wrap is probably a good strategy. You might also add a bit of plastic to keep the 'glass dry when the heater leaks.
