Thread: CV Carbs
Old 09-15-2008, 10:08 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
So I received a map sensor from Coyotes old metro. And was thinking about tapping into the top of the CV carb (above the slide diaphragm, assume I wont interfere with the slide movement) and am having a little bit of trouble theorizing what it will detect if anything.
I want to think that it will be proportional to the needle position, assuming a strong enough signal, because it "looks" like it should work that way. The vacuum compresses the spring. The more the vacuum the higher the needle.
I don't know if it will have enough pressure for good resolution though because it doesn't take much force to compress a cv spring and that diaphragm is pretty large.
Any predictions?
134
