Originally Posted by dcb
I think you have to look somewhere else than the lcd, this is your second one no? Same symptoms?
It is my second LCD. But the symptoms aren't quite the same. The first one put white blocks on the right side of the screen and left the left side blue. This one showed while blocks all the way across until I got the contrast adjusted and now it works right on the left side and has white blocks on the right side.
The meter is on x10 and not x10K ?
Yes, Rx10. The only non-ground wire on the LCD that isn't showing around 30 ohms from ground is 15. I can't think how that could possibly be other than the LCD being damaged.
