Old 09-16-2008, 02:06 PM   #581 (permalink)
dremd
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Originally Posted by celblazer View Post
re: I will rig that up to a momentary on switch for right now. It only takes about 5 seconds to pull -15 on the vac gauge
You can get a vacuum switch that is adjustable so you can set the pump to run automatically when needed(got to be safer then a manual switch. They aren't expensive. I'll see if I can dig up a link.
For example.
Link
Be careful that switch only adjust to 6" of Hg; which may or may not be sufficient for the brakes.
If anyone runs across a switch that can be adjusted much higher (for cheap) I need one also :-)
6 speed ALH TDI
