Old 09-17-2008, 12:25 AM   #5 (permalink)
jamesqf
As you said in the first post, the largest part of energy cost of doing a load of laundry is going to go into heating the water. So you've already got the old washer hooked up to the garden hose. Now you need a couple hundred feed of black plastic irrigation tubing, with hose adapters at the ends. Coil it up in a sunny spot, and do your wash in the middle of the day, with free hot water :-)
