flyback transformer ignition
Has anyone tried to develop a better ignition system based on flyback transformers? It can be designed for a higher voltage than a standard ignition system. The spark plug gap is then widened, so the voltage and therefore the energy stored in capacitance is increased.
I've heard that someone tried to install high voltage capacitors in parallel with the spark plugs, except the timing got thrown off by the charging delay and the engine ran very poorly. But if a flyback transformer with a higher current output is used and specialized control circuits installed, couldn't that problem be solved?
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
