Old 09-17-2008, 02:14 PM   #6 (permalink)
Magister
OBDuino coder
Magister's Avatar
Titine - '07 Elantra GL
I added menu configuration, you can now configure LCD contrast and if you want metric unit or imperial.
I also added "virtual" screens, there is 3 screens, each displaying 4 infos, you rotate through them by pressing a button. It makes 12 infos available quickly. I will add them in the configuration too.
Buttons act like this:
Code:
        realtime display      menu display
LEFT    rotate screen         decrease, select NO
MIDDLE  go into menu          apply and go to next item
RIGHT   rotate brightness     increase, select YES
BTW here is my ELM interface:
