Old 09-17-2008, 06:13 PM   #2 (permalink)
Red
Red's Avatar
Send a message via MSN to Red Send a message via Yahoo to Red
Well I think you've already got the best gearing and engine setup for a Metro seeing as how you have an XFi. Due to the power band of the car, you'd probably only want to drop it into another shell of a similar weight as the Metro. Not sure how you would be able to get it in a Miata since its a RWD car, and the Metro is setup as FWD. With the right trans you could do it, but I think like a VX its the trans that helps you get the FE the XFi gets its fame for
