Old 09-17-2008, 08:02 PM   #2 (permalink)
dremd
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
I know this doesn't answer your question, but I will share what I do know.
Typically gasoline will self ignite on on whatever hot spot is around in the combustion chamber; typically a bit of carbon on either the head, piston, or most likely the spark plug.
One way to avoid self ignition is to do direct ignition, yes there are DI gasoline engines, many are 2 stroke outboards . . . . .
Again, not your actual answer, but I hope it helps . . .
6 speed ALH TDI
