Looks nice wikityler. I remember this from another thread and I like the professional look you're going for. One suggestion, when you install the starter switch, find the kind with a safety cover you have to flip up first so it doesn't accidentally get tripped while the engine is running. Since you've mounted it on a horizontal surface, if something falls on it, a cat for example, that could be really hard on your starter if the engine is running. Keep up the good work.
