Old 01-20-2008, 03:15 PM   #21 (permalink)
buckyball
(See post #36 - this turned out not to be related to modding)
Well, it seems I'm not off to a good start. On the way in to work today (highway speeds), I got a "check engine" light. Given that all of the indicators on the dash looked OK, I can only surmise either (a) tranny oil cooler overheat, or (b) air inlet restriction to engine.
Now I have to go get an OBD-II scanner so I can pull the code. I figure the cost of the scanner is on a par with what the dealer would charge me to pull the code.
'05 Ford F-350 6.0L Diesel, 4x2, Crew Cab, 6' bed
