Thread: car wax
Old 09-21-2008, 12:38 PM   #27 (permalink)
BlackDeuceCoupe
CAUTION: May Stink!!!
BlackDeuceCoupe's Avatar
BDC's Honda CiViC HX/Si - '98 HX/Si (HX Shell/Si Swap)
90 day: 40.56 mpg (US)
Send a message via ICQ to BlackDeuceCoupe Send a message via AIM to BlackDeuceCoupe Send a message via MSN to BlackDeuceCoupe Send a message via Yahoo to BlackDeuceCoupe
Originally Posted by Bror Jace View Post
Guys, there was a thread here not long ago where an aeronautical engineer weighed in. Basically, there are two forms of drag (I forget the terminology) and the drag associated with smooth, slippery surfaces doesn't come into play until you are travelling hundreds of miles per hour (aircraft speeds).
Here is one thread that talks about drag caused by the condition of the surface ... but it's not the one I was thinking of.
Good point!
If a shiny, clean car DOES get better FE, it would only be the case at highway speeds!
A little dust on the surface would not have any measurable effect on the MPG, but if there are sizable clumps of dirt on your car that significantly alters the air flow along its surface, then it WOULD reduce your gas mileage.
Wax, et al, and Rain-X can only improve matters...
.:: B16A2 HX/Si Coupe | '98 HX shell with full '99 CiViC Si swap | 40+ MPG
Listen to the people who fail. They know what they're talking about!
