Old 09-22-2008, 09:24 PM   #1 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Reading a MAP sensor
Here's my notes on experimenting with a map sensor on the bench with a brake bleeder pump and a duino. using a 5 volt reference.
inches of mercury, pin value
ambient, 762
3, 667
5, 619
8, 543
10, 493
14, 390
~25.18 units per inch
Map pinout (your sensor may be different)
Code:
connector  _________
front     (_________)
            A  B  C
           +5  -  Signal (on analog 1)
looks pretty linear till you get near ambient. The cheap gauge on the pump probably has a lot to do with that.
Code:
int mapPin=1;
void setup(){
  Serial.begin(9600);
void loop(){
  Serial.println(analogRead(mapPin));
  delay(500);
