Old 09-23-2008, 08:57 PM   #29 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
I will be able to get a better tune for you this weekend. I have a good exhaust and other than the timing being off a good bit on the bottom end it should be a pretty close setup on the ve table at least.
Adding a turbo to a single compression ring piston won't last long either Swap to the normal metro pistons with 2 compression rings to get a longer engine life with the turbo. But I figure the turbo will give the car a pretty good bit of power if you add it but it will not help mileage at all.
My Convertible Metro XFI Plug in Hybrid Project build log
