Old 09-23-2008, 10:13 PM   #3 (permalink)
dremd
02 Golf TDI Driver
The Golf - '02 Golf GLS TDI
Last 3: 57.98 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
No load Battery voltage is typically 12.7Volts +- .7
While cranking you should see >10volts
While running should be around 14volts
Load test both batteries (In the states most parts stores will test them for free)
If the load test comes back good, check the voltage inside the car.
