Old 09-23-2008, 09:37 PM   #597 (permalink)
bennelson
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
Cleaning up Passenger side wiring
It looks like it's about time I clean up the wiring enough that at least a passenger isn't afraid to hop in the car!
Wiring is a little wild here.
I figured I could run all the cabling under the car in some big conduit.
I used a hole saw to cut into the spare tire well on the back. Then I ran a 10 foot section of 1.5 inch plastic conduit into it with a 45 degree elbow and a short bit of flexible conduit.
Once I had the conduit under the car and connected in back I pulled a LONG section of old welding cable (1/0 size) through there.
I also ran some other misc. cable in there for whatever else I will need to connect from the back to the front. This may include the charger connections, a contactor wire, power to the 12V charger, etc.
That gets to be a lot of stuff to pull through there!!!
I like the looks of the pipe sticking out front. Looks like a 007 car gun.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
