Originally Posted by PaleMelanesian
Bring up the Loop gauge. If it shows Open Loop in that case, you are indeed using no fuel.
You know, I'm not convinced that open loop indicates complete fuel shutdown. I thought I saw on the metro (with the
mpguino ) that the injectors were still firing even when in overrun at a fairly high speed. I think I need to do some more tests on that...
