electronics issue...
All of the wires were cut when aftermarket stereo was pulled out so there's no stock connector. Can anyone give me the color codes for which wires are which? I haven't been able to find my multimeter for months, so it'd be a great help.
I'm going to have to put in all new speakers (they must've been pulled too) so I don't need those color codes.
As an update, the oil pan itself had a tiny leak, but a bit of silicone and JB Weld took care of that. Also took care of the header to exhaust connection, and a hole in the muffler. JB is now officially my favorite epoxy.
Fuel line had an unusual leak a few millimeters from the "front," in the "overlap" area where the tube fits over the extrusion (yes, it is clamped -- it only leaked when wiggled) so I siliconed it and it works fine. There's also a leak at the back connection that seems to be the same thing, but I can't get to it with my huge manly hands and the paltry clearance I get with my ramps. Same deal where it only leaks when wiggled, I might see if my mechanic will let me take a crack at it when I go to get the oil changed 3k miles from now.
