Old 09-26-2008, 12:42 PM   #7 (permalink)
saunders1313
Kawi - '04 Vulcan 800 Classic
90 day: 56.48 mpg (US)
The Monte - '99 Monte Carlo Z34
90 day: 26.52 mpg (US)
I did see Ferris Bueller's Day Off, and unfortunately the movie is accurate, miles will not come off the od without you actually messing with the od and rolling it back yourself. Which is not recommended. But backing out of a parking spot is not recommended simply because you use more gas to back up and then drive forward than you would if you just pulled out of a spot.
Goal one= 30mpg on The Monte by changing the nut that connects the steering wheel to the seat.
