Old 09-28-2008, 08:26 PM   #5 (permalink)
lyd
It smells funny in here.
GeeOh - '97 Metro Base
90 day: 33.41 mpg (US)
Originally Posted by Ford Man View Post
Did you clean the battery posts and cable terminals good before tightening everything up. It's possible if it has been lose long that it might have some corrosion effecting the electrical connection.
I'm a long time believer in being anal about the condition of your battery connections, but in this case it had only been loose since the previous evening when I had it apart to take off a no longer used power lead into the passenger compartment as long as I was monkeying with the ground side anyway. I did give it a cursory brushing, though. Could have been just enough corrosion overnight to make the difference. I'll find out in the morning if that was it, one way or another.
