Old 09-28-2008, 08:37 PM   #6 (permalink)
brucepick
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 51.92 mpg (US)
Originally Posted by BlackDeuceCoupe View Post
~Cool
I've never seen a HX that doesn't get at least 45 mpg!
Yup! BlackDeuceCoupe was exactly right, it turned out.
I got 53 mpg over 137.2 miles, driving it home to CT from NH. I'm pleased!
I drove between 60-70 mostly, sometimes 80. I did coast on downhills, in neutral with engine running. A few fast starts and a small bit of a/c and defrost use. Tires at 37 psi cold because they're sidewall stamped for 35. If it had 44 psi tires I'd have pumped them up harder.
And MetroMPG, I don't know anything about a ScanGauge not being useful with lean burn. Clarify?
My understanding is that ScanGauge calculates fuel consumption based on injector open time and frequency - and calculates that against speed to get mpg. So? Even for hybrids - and the Insight is a hybrid with lean burn also - ScanGauge supposedly does a great job. You do have to set it to HYBRID mode for it to calculate engine-off coasting. If you don't set it to HYBRID it doesn't count distance if ign. is off.
As for MPGuino- yikes. I have a wife and a play in a band and sing in a choir and and and - I don't think I can right now muster the concentration to build that sort of thing. Sorry to disappoint you there. If I didn't have some of these other things going on I might be up to the challenge.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
