Yea so whats to say you couldn't run a steam turbine from the waste heat @ the inducer and the rear turbine off the exhaust to assist in spin. Hook up some brushes and see what happens @ 15k.....?
Sounds like an abilty to make some power just dont know how much as of now. And the vapor mix coming from the inducer side could reduce exhaust temps while staying hotter than from the reservoir. Then be recycled to the steam side @ the manifold.
In short scavenged energy from heat and from exhaust flow turned into current to run a Hydroxy (HHO) Generator thus eliminating the draw from an alternator and giving you increased efficiency vs break even or reduced efficiency for HHO production.
Just built a test tube HHO generator and got 500 ml in 30 seconds. Working on a full scale for better production.
la 8
P.S. go to a semi truck yard or semi truck turbo repair. You can pick up a test turbo and its huge (from the throw out pile) for around 50 bucks. It wont be in perfect condition but it will allow you to tinker for far less. When you find one wiggle the nut at the front and back for play. If it wiggles don't buy that one. Get one with tighter tolerances. Also if you plan on taking the thing apart get them to show you the proper tools you'll need before you leave.
